Engine not warming up
Old Feb 17, 2021 | 11:32 AM
Grey Bearded One's Avatar
Default Engine not warming up
It's only about 20 F here. Usually, the temp gauge is straight up after about five minuets of driving, even in cold weather. Today, I made all the way to work, about a half hour drive, and the temp gauge was only halfway between cold and normal (straight up).
Any thoughts about what's causing this?
Old Feb 17, 2021 | 12:06 PM
ChopperMan's Avatar
Thermostat stuck open
Old Feb 18, 2021 | 10:10 AM
So what causes a thermostat to get stuck?
Old Feb 18, 2021 | 02:18 PM
thermostats have a bi-metallic spring that changes its force with temperature. over time the metals can fatigue etc. Also if you haven't been regularly servicing your coolant (ie drain/fresh water flush/refill every 5 years or so) corrosion can build and make the thermostat sticky. Its usually a good idea when you do a coolant refresh to also replace the thermostat and the overflow reservoir cap as part of that service.
Old Feb 18, 2021 | 10:29 PM
Shefresh's Avatar
Default The engine not warming up to normal temperature
Thermostat stuck open and need to be
​​​​​replace with new
Gtallard
Nov 25, 2019 12:09 AM
hjoannini
Apr 3, 2014 12:31 PM
S70driver
Nov 2, 2009 02:19 PM
sagelore
Aug 13, 2009 10:27 PM
slickz
Aug 10, 2007 10:25 PM
