eratic turn signals...
Old Jun 8, 2009 | 07:24 AM
gatorbrit's Avatar
Default eratic turn signals...
I am having trouble with my turn signals. Sometimes when I turn them on the blink unevenly, or occasionally not at all. If I move the stalk (turn them off and on again) they are usually fine.
I imagine that this is a problem with the switch and not the relay. Is changing the switch difficult, and has anyone else had this problem?
Rich
Old Jun 8, 2009 | 07:39 AM
razak-ms's Avatar
It is a common problems for s60. I have changed the stalk indicator once before and now it is giving problem again as what you have mentioned.
Old Jun 8, 2009 | 07:47 AM
gatorbrit's Avatar
How hard is it to change the stalk? Does that fix it, and where can you get a new one from?
thks
Rich
Old Jun 8, 2009 | 06:47 PM
I would also check the front turn signal sockets they also go bad alot.
Old Jun 9, 2009 | 10:13 AM
adub96's Avatar
Sooooooooo true.
Old Jun 14, 2009 | 11:13 PM
CASS60's Avatar
I just changed me driver's side, front turn signal and it's still blinking quickly and giving me the "Left turn signal failure" error. I was careful not to touch the bulb while I was replacing it. How do I get the error to stop?
Old Jun 15, 2009 | 08:08 AM
adub96's Avatar
It should have stopped upon replacement
Old Jun 15, 2009 | 03:40 PM
vegasjetskier's Avatar
Does the rear turn signal work?
Old Jun 15, 2009 | 06:45 PM
JP's Avatar
JP
I've been having problems lately with this too. It happens with right and left signals. They will blink fast and say "Left (or right) Turn Signal Failure" however all three bulbs are flashing fast.
Old Jun 15, 2009 | 08:41 PM
It is commonly a bad connection inside the socket that causes it.
The turn signal switches go bad as well but will not throw the error message.
Old Jun 16, 2009 | 07:41 PM
CASS60's Avatar
So, what should I do? Try to take it out and put it back in again? Do I have to get a new socket for the light?
My problem is the same as JP's. All the lights are functioning properly and brightly however the "bulb failure" message keeps appearing.
Old Jun 16, 2009 | 08:23 PM
I would get a new socket.
Old Jun 30, 2009 | 06:29 PM
CASS60's Avatar
Thanks Tech. I'll look into it when I get back from VACATION!
BUSTERS60V40
Sep 19, 2011 03:09 PM
RedBrick
Sep 16, 2006 09:06 PM
WagHag
Jun 26, 2006 09:43 PM
bpeabody
Aug 2, 2004 12:16 AM
