Fob doesn't work in cold?
My question is, my keyless entry won't work when it's cold but works when it's warm out? I changed the battery in the fob and it's still the same thing. Also when I came out to the car Sunday morning I had to use my key, of course, 32 deg. outside, it only unlocked the front locks and not the rear ones and the fuel gage quit working and I also couldn't open the fuel door. I checked all the fuses and they were fine so I disconnected the battery for awhile and reconected it, everything worked after that except the keyless entry. Anyone have any ideas why it does this? Thanks, Kevin
Sounds expensive
, I think I might just get rid of the car, it's been nothing but problems since I've bought it and the dealer said the Cat needs replacing, I have 89k miles on it.[:@]
ECM-3420 rear knock sensor, signal too high/ ECM-4801 three-way catalytic converter efficiency, bank 1, all say permanent fault. They said they tested the cat. by the temperatures at the front and rear of the cat.
pete8475
Sep 6, 2009 08:16 PM
