Fuel Pump Problems
Old Aug 23, 2008 | 12:30 AM
jaguar2002's Avatar
Default Fuel Pump Problems
[]Sorry, I think I posted this as a reply.
Can somebody give me any advise on this one?
I am a Newbie. I am having a similar problem with my 2006 S60 2.5 T fuel system 54k miles(maintenance is done at the required intervals by the dealer). Last year in October the car would not start and a fuel sensor was replaced (still under warranty). Last week I had the fuel regulator sensor ($346) replaced due to the check engine light (Code P0089) came on without any warning.The checkengine light was reset and just as I drove up in my driveway the light came back on.
I am not having anyproblems with acceleration; nor is the car trying to stall or cut out on me in traffic. I was averaging 26.7 to 28 mpg in the city until the sensor was changed then I dropped to 24.2 to 25 mpg. I did notice one change prior to the check engine light coming on I stayed at 24.2 mpg for about a week averaging the same speed and distance.
I just took my car back in yesterday; and the dealer is telling me it will cost me $900+ to replace the fuel pump because the pressure is reflecting 52 psi and should read 38 psi. I am kind of confuse; I thought the pressure should read 52 psi and not 38 psi. I am not going to have the work done on the car until I am absolute sure of what is wrong with my car.
If there is a recall on the system please advise; I know that there was a recall on this problem for V70. Please advise if the recall was extended to the S60 series or all turbo regardless of the series.
Thanks.
Old Aug 23, 2008 | 06:23 AM
Default RE: Fuel Pump Problems
The V70 and S60 are almost the exact same car except for the body. SO if the recall covers the V70 it should also cover the S60.
rphud
Sep 27, 2014 06:06 PM
spidersilva
Aug 17, 2011 07:23 PM
scrap88
Apr 7, 2010 09:23 PM
montysano
Sep 9, 2008 11:52 AM
