hard brake pedal with a twist
Last year my '05 S60 had the hard brake pedal problem in the morning. Would go away in a minute or so. Based on what I read in the forums I replaced the switch behind the left headlight and the problem was solved. Well it just started again and a new switch does not fix it this time.
There does not appear to be any audible hissing indicating a vacuum leak from the booster on the firewall.
So what is the next step to solve this issue?
Thanks tech. Is this the motor and pump I see on volvo parts connect for $850? Ouch! The pump does not activate after pumping the pedal. Any sensors or anything to check aside from the switch I already tried replacing before buying the new motor and pump?
Is this something I could try getting out of a junk yard? If so, would you happen to know what models/years I can cross reference with?
jbarnes
06-12-2013 11:46 AM
