Turbocharger Boost Sensor 2002 S60 T5
Old Jul 6, 2010 | 12:12 AM
Jakeman's Avatar
Default Turbocharger Boost Sensor 2002 S60 T5
My 2002 T5 S60 (135,000 miles) is giving two codes
0236 Turbocharger Boost Sensor A Circuit Range/Performance
0237 Turbocharger Boost Sensor A Circuit Low
If I give it moderate to heavy gas from a stop or low RPM's, the car severely stumbles. When the RPM's are up or if I gradually ease into the gas, it does not stumble as bad.
Anyone have any idea what items I should check first? Thanks
Old Jul 6, 2010 | 06:32 AM
MTNBKR's Avatar
I would start by replacing your boost pressure sensor. On my 02 S60 2.4T (if I recall correctly) its on the intake piping between the inter-cooler and the throttle body. I had to replace mine at about 80,000 miles when it threw a CEL. I wasn't experiencing any drivability problems though.
Good luck!
Old Jul 6, 2010 | 07:38 PM
MYS6T's Avatar
looks like there was someone else with same codes this is the link https://volvoforums.com/forum/volvo-s60-v60-10/scanner-p0235-p0236-35084/ and here
http://www.matthewsvolvosite.com/for...hp?f=9&t=18562 GL
benjamin1977
Aug 9, 2013 03:21 AM
nkiritsy
Apr 6, 2012 11:52 AM
endneu913
Mar 28, 2010 11:41 PM
mick1232
Jun 16, 2009 07:49 PM
Tortuga
Jan 28, 2007 12:31 AM
