3 hr Spark plugs with a twist.
Old Dec 7, 2008 | 01:07 PM
MoneypitC70's Avatar
Default 3 hr Spark plugs with a twist.
While I was changing the plugs on my 2000 C70 conv. I found oil completely covering the plug in the second plug cavity from the left. I'm not sure how it worked its way in here....the others were dry exceptthe first plugwhich was loose and was covered in black goo. Any idea how oil could get in andfill this up? I'm worried the head may be leaking.
[IMG]local://upfiles/19871/23B58C914FB147FFAD498E77CBC5E7A6.jpg[/IMG]
[IMG]local://upfiles/19871/3FEB6D34EB1E4327A99524F3A4581D49.jpg[/IMG]
[IMG]local://upfiles/19871/187542616D0E4E908BFC5D35044B48BD.jpg[/IMG]
Old Dec 7, 2008 | 08:53 PM
bimmerd00d's Avatar
Default RE: 3 hr Spark plugs with a twist.
Yeah that'll cause a misfire or two. If the valve cover gaskets are leaking oil will get in there that way. Also the oil filler cap gasket could leak some oil out, but i think it would stay more near the middle plugs. If i'm wrong someone please tell me, but this is a VERY common problem on BMW engines. I had to clean a little bit of it out when i changed the plugs in my g/f's C70 HT.
Old Dec 8, 2008 | 08:33 AM
I would check the oil cap seal and Vent system.
Old Dec 9, 2008 | 07:44 PM
I will check on the oil filler gasket but i don't know to check the vent....however, my valve cover is leaking a bit in the rear.
Thanks for the responses!! [sm=smiley20.gif]
Old Dec 9, 2008 | 08:42 PM
I doubt the cam cover is leaking. I will bet it is from the oil cap seal leaking then there is a spot for it to drain off on the back side.
Old Dec 17, 2008 | 05:32 PM
I just checked the orafice and it is bone dry. I believe it is a collection of oil from a few sloppy oil changes. I will recheck it right before my next oil change and right after. Thanks for the response!!
Old Dec 17, 2008 | 05:33 PM
Oddly enough it never caused a misfire....although it is idling much better.
Old Dec 17, 2008 | 05:37 PM
Keep us updated.
volvoQ's
Apr 23, 2011 10:00 PM
futbolfan15
Apr 2, 2010 09:56 PM
rationull
Jun 11, 2008 11:27 PM
jnduke
Apr 11, 2008 08:20 AM
