help Door locks, new to forum
Old Oct 10, 2007 | 11:36 AM
shiftrider's Avatar
Default help Door locks, new to forum
Hey guys, im having problems with my 2002 S60 AWD.
The driver side door will no longer lock (power, it will lock if i manually push it down), and the rear driver side door constantly comes "open" turning on the overhead lights. Are the connections loose? Ive had a lot of electrical problems with this car, should i replace the computer? Does that need to be done at the dealer?
Does any one know how to remove my door panels so I can check/replace the parts I need.
Thanks,
ben
Old Oct 11, 2007 | 05:55 PM
Default RE: help Door locks, new to forum
There is clips on the bottom of the panel.
Then remove the outer part of the pull handle and remove the 2 screw and it will come off.
You will need to replace the entire lock assembly.
rcvolvo
Jun 3, 2012 02:25 PM
menguchita
May 30, 2011 03:22 PM
billatCOBY
Aug 16, 2005 10:52 PM
dbuckland
Jul 12, 2004 05:33 PM
rcbelmont
Apr 16, 2004 12:54 AM
