Help identify this part.
Old Jan 29, 2009 | 05:01 PM
blankooie's Avatar
Default Help identify this part.
picture: [redacted]
This is what connects the regulator arms to the rails on the front passenger window. It broke today (ice got stuck in the window, cold probably contributed to it cracking) and I have it back on there to hold the window up, but I can't use the window or the ball joint starts to pop out.
Thanks for your help
Old Jan 29, 2009 | 05:17 PM
TIPSP's Avatar
Got Boost?
I dont know which model you have but check here: (Click Here)
Volvo Window Regulator Sliding Pivot
Old Jan 29, 2009 | 05:39 PM
blankooie's Avatar
Thanks! That's definitely it!
Old Jan 29, 2009 | 05:43 PM
TIPSP's Avatar
Got Boost?
No problem
Old Jan 30, 2009 | 05:14 PM
blankooie's Avatar
Its in and everythings working now. I was able to pick up the piece at a local dealership for $5 which I have no complaint paying for.
The arm was also bent a little but I got that straightened out (pun intended).
I wish I knew before hand how much pressure it takes to get the ball into the socket. I had to use a large pair of pliers to snap it into place. My only concern is that for the first couple of times I moved it up and down, it would stop at the top and then automatically go all the way down. It seems to have worked its self out though.
Old Jan 30, 2009 | 05:16 PM
TIPSP's Avatar
Got Boost?
Glad it is working now!
borimrr
Apr 12, 2013 05:40 PM
alieas
Aug 7, 2012 09:35 PM
1983240DLWAGON
Mar 20, 2012 12:46 AM
Leoj
Sep 28, 2011 11:14 PM
bunky3301
Mar 25, 2008 06:38 PM
