Help with location of the Fuel Pressure Regulator
Old Sep 8, 2015 | 06:21 PM
Jennifer Highton's Avatar
Default Help with location of the Fuel Pressure Regulator
Hello,
We have a 2005 Volvo S60 and have been having trouble with the fuel system.
We had a check engine light on and the code was for the fuel filter or fuel pump. The car eventually started to turn off on its own while driving. We took it to a shop and they replaced the fuel pump and fuel pressure sensor. About 50 miles later the check engine light went on again with code P0191.
It looks like the only thing left to replace is the Fuel Pressure Regulator. I cannot find a location via the internet nor could I find one while searching the forum.
Also, we could not locate the fuel filter. The mechanic said it was in the fuel pump. But I understand it to be a screen. If there is one outside the fuel pump, help with that location is helpful too. We found directions to look under the car toward the rear tire, but, there's nothing there.
Any help is appreciated! (Pictures prefered )
Thank you!!
Old Sep 8, 2015 | 06:48 PM
ES6T's Avatar
There is no regulator and if you have a steel fuel tank, no filter either.
Old Sep 8, 2015 | 06:55 PM
Okay, thank you.
If neither of those exist in my car and we already replaced the fuel pump and the fuel pressure sensor. What could be the problem??
Old Sep 9, 2015 | 10:45 AM
ES6T's Avatar
Could be the fuel pump control module
MntnDewMan
Apr 3, 2024 04:05 PM
PMOURASSA
Sep 9, 2015 10:15 AM
slsnumber1
Mar 15, 2011 02:55 PM
walrus
Apr 17, 2010 09:57 AM
hoffmandirt
Jan 24, 2010 06:25 PM
