Help - S60 Loosing Power at Highway Speeds
Old Jun 3, 2011 | 11:29 AM
DB Volvo S60's Avatar
Default Help - S60 Loosing Power at Highway Speeds
I own a reasonable good S60 2004 w/ 170k miles
My problem is a loos of power at speed from 55 and up.
Car was stuttering (nearly stalling) on acceleration from a full stop and replacing the spark plugs and the air filter seems to have corrected that problem. But I am still having the low power at highway speeds.
The engine seem to stutter as if one or more cylinders was not firing (very mild).
I am thinking this is the fuel pressure sensor located on the fuel rail.
Any help would be greatly appreciated.
The car is not indication any trouble codes so far. I have a scanner tool and keep getting the no codes present indicator.
Thanks in advance.
Old Jun 5, 2011 | 05:19 PM
03S60's Avatar
replace fuel filter, it may be clogged
Old Jun 5, 2011 | 05:29 PM
eeeewidner's Avatar
There are several threads on this site that have this symptom in it. If you have a graphing scanner look closely at the ETM for loss of voltage when it happens. It will not throw a CEL unless it is broken.
jbyszewski
Mar 24, 2020 03:33 PM
sek8031
Mar 4, 2009 07:13 PM
thompson07
Feb 2, 2009 06:28 PM
T64FUN
Apr 30, 2008 05:53 PM
