intermittent ac blower
Old Aug 5, 2008 | 04:03 PM
carlmurdock1's Avatar
Default intermittent ac blower
I have read every thread and cannot find one that addresses my problem. 2001 S60, manual ac. Works perfectly sometimes, blows good, speed control worksfine, then I will get in and start the car and no blower. Replaced cabin air filter and jiggled every connection I could find with no results. A few times a bump or a hard turn will make it come back on but that has become rarer lately. Does not relate to temperature or how long car is turned off as far as I can tell. Suspect some kind of sensor but none mentioned in threads or literature. Anyone have any ideas?
Old Aug 5, 2008 | 05:54 PM
Default RE: intermittent ac blower
Resistor might be bad.
Old Aug 5, 2008 | 06:36 PM
Thanks, wondered if that was possible, can they be intermittent? when the blower works the speed control function is fine. Is that controlled by theresistor?
Old Aug 5, 2008 | 06:40 PM
Yes the resistor controls it. Yes I have seen many act just like yours.
Old Aug 5, 2008 | 06:58 PM
thanks again, I am going to try a new one. Any hints on how to get the glove box out? removed 6 screws and everything dropped some but cannot get it out without worrying about breakage. Am i correct that there is wheere the resistor is located?
Old Aug 5, 2008 | 07:06 PM
You need to remove the entire blower motor assembly. Then remove the motor and it is there. Also I bet the shock is still holding the glovebox in.
Pull the end plastic cap off the end of the dash by the passenger door to see the shock. But they usually break when going back on.
Old Aug 5, 2008 | 07:24 PM
shock is off, resistance to rermoval is at the bottom of the assembly, feels very solid. have I missed some screws? removed 2 at top and 2 on each side. Also have kick plate off. Cant find anything else to remove. Sorry to drag this out so much.
Old Aug 5, 2008 | 07:38 PM
Close the glovebox and look along the bottom I think there is 3 more.
Old Aug 5, 2008 | 07:42 PM
thanks for all the info, I really appreciate this forum. Helps immensely with maintaining this car on fixed retirement income
Old Aug 5, 2008 | 07:47 PM
Glad we can be here to help you and other members.
Badmotorfinger
May 10, 2009 08:34 AM
W35
Dec 16, 2008 09:40 PM
Evo 850
Dec 6, 2007 01:51 AM
Mass850
Jan 11, 2006 11:29 PM
