intermittent idle issues
Old Nov 19, 2011 | 10:46 PM
Nichals's Avatar
Default intermittent idle issues
hello again, so my 2004 s60 turbo 2.5 has been having an interesting issue as of today
idle seems rough, more so than normal as well as randomly it pulses and for that moment it is an exceptionally rough idle but only for a moment, it does this off and on hot or cold.
when I unplug my mass airflow sensor (maf) the idle stabilizes and everything's fine no sputtering of any sort. I assume my MAF sensor is bad, I cleaned it and it helped but only marginally, should I just go ahead and replace it? or is there something else i should look at
more info, last week i changed my timing belt and its been running 100% up till this morning when i did that i replaced the pullys, water pump and sparkplugs.
Old Nov 20, 2011 | 03:23 PM
jda2000's Avatar
you answered your own question.
if the car idles better with the MAF unplugged, then yes you need a new one.
Old Nov 20, 2011 | 09:09 PM
Nichals's Avatar
that's what I had assumed, as I have already ordered one, I'm just waiting for it
I wanted to make sure it wasn't anything like the maf relays, it's hard to believe that an airflow sensor can make such a big difference. I drove the car for an hour today 30 minutes with it plugged in and 30 minutes back with it unplugged all the while with my scanner plugged in. after inspecting the sensor itself I noticed that the glass around the resistor was cracked (don't know how but ehh stuff happens)
thanks for the input though I was just a little leery about spending another 180 on the car as this week I've put in 600 ish and next weekend another 40 to change the oil.
Old Nov 22, 2011 | 05:55 PM
Nichals's Avatar
well i got the MAF in today
but now the car runs worse!?
any ideas? could there be some sort of learning period?
Old Nov 23, 2011 | 08:45 AM
jda2000's Avatar
did u get bosch or aftermarket MAF? is there a CEL light on?
these swede babes only like bosch
Old Nov 23, 2011 | 07:10 PM
Nichals's Avatar
i got this
Cardone Reman/Mass Air Flow Sensor (74-10090) | 2004 Volvo S60 5 Cylinders 2.5L Turbo DOHC | AutoZone.com
its "Bosch" or so labeled but its remanufactured by acordone
Old Nov 24, 2011 | 01:29 PM
jda2000's Avatar
get your money back from autozone and get a new Bosch from eBay.
I've seen the new ones for about $100
Old Nov 24, 2011 | 06:08 PM
Nichals's Avatar
ok i dident think ebay would be a safe bet but im willing to to anything at this point lol
one thing i wanna mention it that when i have my scanner pluged in and im monitoring then engine rpm every once in a while it will shoot up to 9,000-12,000 rpm obviously this is not shown on my tachometer as it goes up to 8k the needle dosent so much as flinch however every time it does this the car shakes but not everytime does the car shake and the rpm spike. i was thinking maby i should replace the rpm sensor (yet to look up whitch one it is) aswell as the maf
Old Nov 24, 2011 | 06:26 PM
Nichals's Avatar
sounds like its called either the
impulse sensor
crankshaft position sensor
or reference sensor...
whatever its called im going to pull it out and clean it as i hear it can get contaminated with metal shavings
Old Dec 2, 2011 | 05:43 PM
Nichals's Avatar
ok here it goes
cleaned MAF sensor
resealed all connections on all vac lines
replaced spark plugs
replaced angle position sensor
seafoamed everything
the car is now faster than the day i bought it!
badfish2282
Oct 9, 2012 03:29 PM
scifigreg
Aug 5, 2012 04:27 PM
sabine
Feb 28, 2012 08:38 AM
theboy455
Feb 19, 2008 09:21 PM
