jacking up the car
Old Mar 27, 2009 | 10:46 PM
gatorbrit's Avatar
Default jacking up the car
I'd like to change my own oil. Do I need to jack up the car? If so where are the jack points for axle stands, or should I use ramps?
Thanks
Old Mar 27, 2009 | 11:58 PM
01_fast_ride's Avatar
I use a jack with jack stands. A ramp would work too. I place the jack under the large flat spot behind the sub-frame mount (it's roughly a large triangular area). Then I place the jack stand right under the sub-frame mount. Ramps are okay but some cars are so low that an additional 'mini-ramp' has to be used to avoid scraping the front bumper. You're also limited to the kind of work that can be done on the car (with ramps).
You can do a search as you will need a filter wrench and you will want to know how to reset the service reminder message when it pops up.
vpatrol
Oct 3, 2009 08:26 PM
Balvenie
Jul 17, 2009 10:42 AM
bw77
Apr 26, 2009 05:54 PM
nicolaselias
Apr 12, 2009 07:52 PM
rationull
Apr 3, 2007 01:18 AM
