Key blade use on 2016 V60
Old Nov 30, 2017 | 10:05 PM
wysocki's Avatar
Default Key blade use on 2016 V60
I was wondering what I'd do if my valet parking guy went home for the night and took my remote key with him. Here's what the manual says:
If the remote key does not function normally
(weak battery, etc.), the vehicle can be
unlocked with the detachable key blade.
1. Remove the detachable key
blade (p. 151) from the remote key.
2. Press the key blade approx. 0.5 in. (1 cm)
straight up in the hole on the underside of
the keyhole cover.
> The cover will come off due to the
pressure exerted when the key blade is
pushed upward.
3. Insert the key blade as far as possible in
the driver's door lock. Turn the key blade
to unlock the driver's door. This will trigger
the alarm.
4. To turn off the alarm, insert the remote
key
in the ignition slot...
Step 4 would be really hard to do since I DON'T HAVE THE REMOTE ANYMORE!!!! Really, what good is the key blade if I also have to have the remote in order to use it?
Old Dec 2, 2017 | 02:08 PM
ssicarman's Avatar
You are pooched. No remote key and you can't start the car at all.
The mechanical key is there to get you into the car to open things up to boost the car in the event of a dead battery. Also allows you to put the car into valet mode.
Michelformika
Oct 12, 2017 04:31 PM
Drizzt321
May 23, 2017 12:54 AM
ronsivillo
May 10, 2017 06:18 PM
Pouch
May 8, 2015 09:03 PM
