Knocking When clutch is disengaged
Old Oct 25, 2021 | 07:56 PM
wills60r's Avatar
Unhappy Knocking When clutch is disengaged
Hey, I'm new to the Volvo community. I recently purchased a 2004 Volvo s60r and I noticed a knocking sound coming from the engine bay, I then realized that the knock would go away when the clutch was engaged. Any ideas on what this issue could be.
Old Oct 26, 2021 | 02:04 PM
when you say the clutch is engaged - you mean the pedal is out (meaning power is going through the clutch into the transmission)? if you are hearing odd sounds when the pedal is pressed down and the clutch is disengaged), then the likely causes are the throw out bearing or possibly something in the pressure plate, fly wheel or clutch plate. Any sense of drag when shifting gears to suggest the clutch is not fully disengaging?
Old Oct 26, 2021 | 03:21 PM
wills60r's Avatar
yes sorry i hear the noise when the clutch is up and when i clutch in the knock stops
Donzi
Nov 5, 2012 10:27 AM
1995Volvo850
Jun 2, 2012 10:25 PM
joey 100
May 6, 2010 01:53 PM
timwu12
Mar 30, 2010 01:29 PM
cgould1971
May 21, 2007 11:24 AM
