LOW BATTERY VOLTAGE
LOW BATTERY VOLTAGE
I just bought a 2001 Volvo S60 about 3 months ago.
I had the Low Battery Voltage message pop up and so I replaced the battery since it was already 5 years old anyway, but after about two hours or so of driving, the Low Battery Voltage message pop back up. Could it be the alternator going or gone bad? If so, anyone ever replaced one before. I looked under the hood and it looks simple enough except it looks like I have to remove the Power Steering pump to get to the Alternator bolts. Am I correct?
Ideas?
William
Ideas?
William
RE: LOW BATTERY VOLTAGE
The problem is more likely to be the voltage regulator. According to my local Volvo service manager the alternators rarely go bad on these cars. I had a similar problem with my '01 S60. I had a fairly new battery that suddenly went bad. I charged it up but wasn't satisfied the problem was fixed. I immediately scheduled it to be looked at. The car was still under CPO warranty so it only cost me $50. With out the warranty the repair bill would have been in the neighborhood of $250 - $300.
Hope this helps.
Good luck.
Hope this helps.
Good luck.
Did you ever figure this out? Im having the same problem with my 2001 V70.
