Low Beam - one okay / one dim
Old Sep 20, 2015 | 12:13 AM
bikerider58's Avatar
Default Low Beam - one okay / one dim
2004 S60
The left low beam is fine, the right low beam is very dim and the high beam bulbs are on at low voltage. No bulb failure message. Fuses are good.
Changed the bulb with no change.
I did not check the voltage, but it is as if the light is on a dimmer.
What should I check?
Old Sep 20, 2015 | 11:52 AM
Solved - on another forum I found a thread covering corrosion in the connector to the headlight assembly. It wasn't the easiest thing to get to, but after disconnecting I found corrosion on the pins. I used a dental pick and electrical contact spray to clean it. Then used some dielectric grease on it before plugging it back in.
Worked fine.
Volvo_Neps
1998-2000 model year V70
Sep 12, 2024 06:53 AM
mhphoto
Dec 13, 2009 08:59 PM
volvo40_2k
Jul 28, 2009 09:18 PM
VolvoS40SE
Aug 1, 2008 10:14 AM
freakpower
May 17, 2005 06:47 PM
