martsubob
Old Feb 18, 2010 | 04:49 AM
martsubob's Avatar
Default martsubob
How do I change the front brake pads on my 2002 S60.Thank you. Bob
Old Feb 20, 2010 | 06:47 AM
cb1313's Avatar
Default Brake pad change ??
Hi, it really depends on your skill and available tools and work location.
If you have a safe place and tools it should take maybe 1 1/2 to 2 hours.
Once the wheels are off you have a couple clips and pins and the pads are out. There are many companies that make brake pads, get the best you can afford. I purchased my from Autozone and they did not fit without doing some grinding on the new pad.
You will need to bleed the system a little, can you do that ?
Now... I worked in aircraft hydraulic for 25 years think nothing of doing this.
I would check with a local shop that works on Volvos for a price.
Questions...? Cb
Old Feb 21, 2010 | 11:06 AM
martsubob's Avatar
Thanks for the advice.Coincidentally I also worked on a/c for 25 years including a hydraulic workshop in Singapore.(Fleet Air Arm). Bob (MARTSU)
