Massive oil leaking
Old Oct 6, 2024 | 02:08 PM
Arpad's Avatar
Default Massive oil leaking
the Pcv system was clogged, the oil leaked out at the cam seal. the oil pressure light came on for a few seconds. could I have engine damage?
Old Oct 7, 2024 | 10:03 AM
not likely unless you drove a while with the light on. First thing to do is to drain the oil through filter paper to look for any metal bits. Refill the oil and give it a listen - no odd noises means your good and its time to service the PCV. You can also have the shop drop the oil pan and clean the bottom end and service the oil pump if you are concerned. Check if there's any recommended updates to your oil pickup for your model (ie a new part #). You can also have a shop with a scanner/VIDA check oil pressure for you prior to doing the PCV for peace of mind.
RJSV70
2001-2013 model year V70
Sep 9, 2023 03:39 PM
RJSV70
2001-2013 model year XC70
Sep 9, 2023 03:38 PM
badfish2282
Sep 6, 2012 01:36 PM
endneu913
Nov 21, 2010 10:53 AM
reddboyy
Aug 1, 2009 10:31 AM
