Motor mount gone bad?
I've got an '06 S60, and when I'm stopped and then accelerate, I can faintly hear a slight popping and feel kind of a flexing coming from within the engine compartment. I should probably have my motor mounts checked? They were replaced under warranty just over a year ago.
If you take the car to a suspension shop they should be able to tell you what is bad or worn under there. It can be anything from a worn axle to a bad tie rod end or ball joint. If you jack the car and try to whiggle the wheel up & down then left & right and see if you have any play in the suspension. Report back with any play. It's safest to have the car on jack stands.
