Multiple Cylinder Misfire, Any Ideas?
Old May 17, 2021 | 03:31 PM
Krystelle Rolling's Avatar
Default Multiple Cylinder Misfire, Any Ideas?
Hi,
A week ago check engine light appeared, car started shuttering while in idle and while accelerating. Code diagnosed at Auto Parts was P303. Ordered a new ignition coil (Bosch) and new spark plugs (Denso) which were delivered a week later. Did minimal and very careful driving during this time, ~ 3-5 miles per day.
After replacing all spark plugs and the coil on cylinder 3, ran the code myself and now saw 3 codes: P300, P303, P304. Car feels insignificantly better WHILE driving but still has a lot of trouble accelerating/changing gears , and is still shaking when accelerating and idle.
If I try to drive up a hill or accelerate too quickly Check Engine flashes and prompts “Slow Down or Change Gears”
Any ideas? I am thinking swap all the coils, but am not totally confident it is a bad coil pack and would really appreciate some external opinions before buying the kit.
Solved: installed new set of ignition coils, almost 10k miles later still drives great, no issues.
Old May 18, 2021 | 06:57 AM
Dingus's Avatar
First thing first, you really don't want to drive your car while it's misfiring. You're only going to hurt it. Swap your coil packs around between a misfiring cylinder and one that isn't to ensure those are not the problem.
Did the car overheat at all?
Old May 18, 2021 | 09:35 AM
misfires can be caused by weak spark, incorrect mixture or compression issues. If you swap coils, inspect replace plugs while doing so. You may even want to do a compression test since you'll have the coil off and the plug out. Some other ideas: Inspect the wire harness to the coils, particularly the connectors which can crack. Check your intake air path for any air leaks/tears/cracks etc. Any oil or water consumption? Pop off the intake air hose - any signs of oil getting into the intake from the PCV?
usmcvolvos40
Jan 25, 2012 10:16 AM
beauch3
May 20, 2011 05:54 AM
Rwoodru1@hotmail.com
Jul 12, 2010 12:38 PM
Sir_Lance
Dec 29, 2009 10:11 PM
exceter474
Nov 4, 2009 04:48 PM
