My Car Has an Oil Warning !!!
Old Mar 23, 2020 | 05:00 AM
Snn Ln's Avatar
Exclamation My Car Has an Oil Warning !!!
Herkese merhaba. Ben 2006 Volvo s60 2.4 t5 motor 199000 km var. Bu motor yeniden inşa edildi, 135000 km idi. Çünkü motor sıcaklığı yüksek. 5000-6000 dev / dak sürdüğümde ve araç (650-700 dev / dak) altında "yağ basıncı düşük, aracı durdurun" olmadığını motor bir yağ hatası veriyor. Sonra araba sürüyorum ve rpm yükseliyorsa yağ hata lambası kayboluyor. Yağ pompası, yağ basınç sensörü ve yağ filtresi çalışıyor. Yavaş sürersem (maks. 3000-4000 rpm) uyarı vermeyin. Bu konuda bilginiz var mı? Ne yapabilirim? Tesekkurler.
Old Mar 23, 2020 | 10:07 AM
Google translation: Hello to everyone. I have 2006 Volvo s60 2.4 t5 engine 199000 km. This engine was rebuilt, it was 135000 km. Because the engine temperature is high. When I drive 5000-6000 rpm and under the vehicle (650-700 rpm) the engine gives an oil error that "oil pressure is low, stop the car". Then I drive and if the rpm rises, the oil error lamp disappears. Oil pump, oil pressure sensor and oil filter are working. Do not give a warning if I drive slowly (max 3000-4000 rpm). Do you have any knowledge about this topic? What can I do? Thank you.
Start by removing the oil pan, inspect for debris and sludge. Then check the oil pick up screen for same. you may want to consider installing new o-rings for the pump. Finally make sure you use the correct weight oil per the owners manual for your local climate - 10W-30 is standard for most.
Ross Miner
May 14, 2019 04:22 PM
rspi
Aug 25, 2013 07:47 PM
rspi
Aug 23, 2013 06:54 PM
mountain_tamer82
Jul 2, 2012 09:24 PM
850T5M
Jan 22, 2010 12:33 PM
