Need Help Identifying issue
Old May 15, 2023 | 11:39 AM
zmm's Avatar
zmm
Default Need Help Identifying issue
My tire pressure light came on this weekend, so I checked my tire pressure on all four tires and one was low. I filled it up but as I did i noticed these 2 wires hanging from the front driver side wheel well of the car, I dont know if these wires caused the tire pressure light to come on, or even how long these wires have been hanging thier.. My tire pressure light is still on even though all my tires are filled...
I need help identifying these wires, or how can I easily fix them.
Thankyou in advance
Old May 15, 2023 | 12:36 PM
Dingus1's Avatar
What year is your car? When you put air in the tires or get new tires, you need to re-calibrate the tire monitors using the center console.
Easiest way to find what those wires are for is to follow where they go. My first assumption is a fog light plug, but the plug is gone.
Old May 15, 2023 | 03:15 PM
zmm's Avatar
zmm
2016 volvo s60..... and if so how do i do that exactly
Old May 16, 2023 | 06:13 AM
Dingus1's Avatar
- Press the MY CAR key in the center con-
sole control panel and select Settings,
Car settings, Tire pressure.
- Press OK/MENU, select Calibrate tire
pressure and press OK/MENU again.
Old May 16, 2023 | 06:39 AM
zmm's Avatar
zmm
Thankyou
zmm
May 16, 2023 03:42 PM
Kristi Ford
Nov 22, 2017 06:48 AM
strom19
Feb 20, 2012 10:00 PM
mga56grg
Jan 19, 2012 08:01 AM
m1964
Jun 29, 2010 12:33 PM
