need suggestion on fuel system treatment
Old Feb 18, 2011 | 12:23 PM
volvovera's Avatar
Default need suggestion on fuel system treatment
Does any one has experience to use fuel system treatment/cleaner?
which brands are better?
Whether it is OK to use fuel system cleaner, like Lucas or Motul, on Turbo cars?
Thanks in advance!
Old Feb 18, 2011 | 12:30 PM
avguy's Avatar
For everyday use or are you already having problems?
Old Feb 18, 2011 | 02:27 PM
volvovera's Avatar
Philip,
My car has 102,000 kilometers and for about 1 month ago I started to hear a whistle noise coming from fuel pump. And I saw some threads mention that the similar noise was just gone after they used fuel system treatment/cleaner. So I wonder whether I can give it a try before I consider a fuel pump replacement.
Since Volvo does not recommend the use of external fuel injector cleaning systems, so I have a little bit concern on that
Old Feb 18, 2011 | 05:07 PM
avguy's Avatar
The master mechanic I consult with recommends Techron for cleaning.
http://www.amazon.com/Chevron-Techro.../dp/B00092893E
I use Lucas fuel treatment regularly as a preventative.
http://www.lucasoil.com/products/dis...el%20Treatment
Old Feb 18, 2011 | 07:39 PM
volvovera's Avatar
Philip,
Thank you so much! I will try what you suggested.
Have a nice weekend
Old Feb 18, 2011 | 08:56 PM
JDusza's Avatar
Seeing this thread has me wondering about additives or synthetics, in general.
I have used SeaFoam in the fuel systems of just about all my engines. I have literally heard and felt the improvement on outboard engine try-outs. I am a believer.
What about oil additives? Should I run with an additive or switch to a synthetic at 114k miles on my 2.5T?
Thank you,
J
Old Feb 19, 2011 | 09:46 AM
ed7's Avatar
ed7
Techron is an excellent additive for maintenance twice a year.
It will NOT solve the problems of an ailing fuel pump. If you think you have fuel pump problems, start by checking its output pressure and go from there. Don't overlook the filter.
Ed
Old Feb 19, 2011 | 05:30 PM
volvovera's Avatar
I only found Lucas Upper Cylinder Lubricant & Injector Cleaner in Walmart today. What is the difference between this and Lucas Fuel System Cleaner? Are they have the similar effect on cleaning the whole fuel system?
Old Feb 19, 2011 | 07:55 PM
JPN's Avatar
JPN
Originally Posted by ed7
techron is an excellent additive for maintenance twice a year.
It will not solve the problems of an ailing fuel pump. If you think you have fuel pump problems, start by checking its output pressure and go from there. Don't overlook the filter.
Ed
+1.
Jpn
240Wagon734
Nov 30, 2014 06:11 PM
PetarYanev
Jan 22, 2014 03:49 PM
A MAL3 NURSE
Jan 23, 2011 03:50 AM
mdavies013
May 10, 2009 09:59 PM
ricky
Feb 28, 2009 07:51 PM
