New S60 Owner
Old Nov 24, 2007 | 11:10 PM
zaldog's Avatar
Default New S60 Owner
Hi all just bought a 2002 S60 AWD yesterday so far so good it has 77K on it anything I should look out for at this mileage? I did notice a message for regular service? Does that mean an oil change? Thanks for any inout, love th car faster than I thought has Nav system to :-).
Old Nov 25, 2007 | 08:15 AM
jks2's Avatar
Default RE: New S60 Owner
AWD should be a turbo. If that is the case then you don't have to worry about the ETM. Yours will be a Bosch vs. the Magnetti-Marelli in the NA models. Getting close to time to change the timing belt. Also, look forward to ****ling problems with the electronics. Your owners manual will list items to be checked/changed at each service interval.
Old Nov 25, 2007 | 08:56 AM
zaldog's Avatar
Yep 2.4T it's a turbo, whats the deal with the ETM? Just Ignore the message?
Old Nov 25, 2007 | 05:27 PM
jks2's Avatar
If you look around on here you can find the steps to turning the message off. The ETM problem was with 01 and 02 NA S60's. The ETM was too sensitive to carbon build up so it would go into limp mode. The recall consists of cleaning it and reprogramming the computer. Again, the problem was only with the Magnetti-Marelli ones in the NA 2002 S60's. Yours has the Bosch ETM so you should have no problems. I wouldn't totally ignore the message and do an oil change, etc.
Old Dec 5, 2007 | 09:58 PM
zaldog's Avatar
Took the car to Volvo today, they said I need a new Bosch ETM $1075.00 plus a bunch of other work neglected by previous owner. Your right Bosch ETM not part of recall. Guess the Bosch ETM does have problems, glad I got a warranty with this car.
Old Dec 6, 2007 | 05:23 AM
jks2's Avatar
OUCH! Sorry to hear about that. Like you said, at least you got the warranty.
SHBazTBone
Apr 18, 2014 04:25 AM
shimby
Nov 21, 2008 07:14 PM
MirzS60R
Jan 3, 2006 09:00 PM
mahie023
Nov 9, 2005 10:14 PM
Bender
Oct 3, 2005 08:54 PM
