No start condition - starter cranks no ignition
After having the PCV system replaced, the 2.5t Turbo with will not start. The starter cranks, the timing belt spins, the water pump and accessory belt spins but the engine does not start. There is pressure in the fuel bar, check with the schrader valve. There is no spark in at the plugs. I Ann it sure if fuel
is coming out of the injectors. I have checked all of the connections to ETC, MAF, fuel
injectors, thermostat, TPC valve, cam sensor and crank sensor. Triple checked all
vacuum hoses.
batter has been charged to 100%
tried resetting ECM with disconnected battery
replaced plugs with Volvo plugs
replaced cam sensor
Any Help would be appreciated
vacuum hoses.
replaced cam sensor
nightmarevolvo
02-04-2023 06:20 PM
Cleaner13
05-25-2014 11:53 PM
