No start engine performance reduced message
My wife was backing out of the garage this morning and the car died. 2003 s60 2.4T. The engine turns over but will not start. I can't find any active codes, but the message center sais reduced engine performance. I checked all of the fuses and they seem fine. I pressed the schrader valve in on the fuel rail and no gas came out. Fuel pump?
I would guess the fuel pressure sensor. If it is faulty it can cause that condition. Volvo has a recall on it. If it turns out not to be the sensor, at least you can rule that out. Here is the recall info: http://www-odi.nhtsa.dot.gov/cars/pr...type=DrillDown
Agos
Sep 8, 2008 05:22 PM
