fault code
Old Mar 3, 2009 | 01:53 PM
edgey99's Avatar
Default fault code
hi all not been on for a while s60 t5 2001
i have this engine check light on my mate read the codes and he got p0121 Throttle Position Sensor/Switch A Circuit Range/Performance Problem can anyone shead any light on this and the parts i will be needing ,already had the etm clean and software update new maff ,new coils
thanks
roy
Old Mar 3, 2009 | 08:05 PM
The ETM might be bad it is under a 10 year 200,000 miles warranty if it is bad.
Old Mar 4, 2009 | 12:36 AM
edgey99's Avatar
hi tech thanks for replying
the etms are real expesive are they not whats the throttle peddle sensor will that not be it , if it is the etm volvo will need to do the work is that correct
Old Mar 4, 2009 | 07:19 PM
Yes Volvo will need to do the work.
The TPS is the ETM. Most generic scanners will read it as a TPS.
The ETM job is like $1200.00.
Old Mar 8, 2009 | 10:58 PM
Volvotek's Avatar
make sure your car has had the recall 155. if so they will clean the trottle before replacement
v1lcins
May 20, 2022 10:53 AM
volvojunkie
Mar 15, 2009 12:35 PM
elchingon2002
Mar 11, 2008 10:41 AM
safari
Dec 10, 2007 07:46 PM
mddavis
Jul 19, 2007 02:36 AM
