noisy brakes
Old Sep 9, 2007 | 12:58 PM
ranny528's Avatar
Default noisy brakes
hi all does anyone know how to silence squeeky brakes.
i have had the front and rear pads off and copper slipped them but i still have the squeel.
just read a post that the hand brake has different shoes could this be the problem as when rolloing slowly if i apply (gently) the handbrake it make a deafening squeel.
Although when applying the brakes it probably don't move these shoes could this somehow be the problem and if so can i take them off and copper slip them.
many thanks ranny528
Old Sep 9, 2007 | 11:41 PM
JPN's Avatar
JPN
Default RE: noisy brakes
Hi ranny,
In general, drum-type brake shoes (the half-moon shaped shoes used on the parking brake) are not known to cause squeaks. But if you pull on the parking brake and the brakes squeak, something may be loose and vibrating at a very high rate, causing high-pitch noise.
The best thing to keep away squeaky brakes for Volvos (as well as other cars), is:
1. Use OEM pads, rotors, shims & hardware.
2. Clean everything good before re-installation and sand off rusts if necessary.
3. Apply CV-joint grease (or any molybdenum-based grease) or silicone-based brake grease onto every metal-to-metal contact areas, EXCEPT the friction surfaces. Generic "brake-quiet" compounds are useless.
4. Be easy on the new brakes for the first 100 miles or so.
I'll let other guys chip in.
Good luck,
JPN
Old Sep 11, 2007 | 04:16 PM
ranny528's Avatar
many thanks for your reply
in the past copper slip had always worked, but i will try your ideas and will let you know
cheers ranny
Old Sep 13, 2007 | 08:58 AM
JPN's Avatar
JPN
Hello Ranny,
My pleasure, I hope it goes well for you.
Best of luck,
JPN
Old Sep 15, 2007 | 07:41 AM
Are they OEM pads?
Ciguri
Jun 9, 2011 04:09 AM
dcox612
Feb 21, 2006 09:04 PM
spinningcain
Feb 2, 2006 01:17 PM
meerkat
Aug 16, 2005 01:07 AM
05s40
Mar 10, 2005 11:40 AM
