odd dash light problem
Old Oct 18, 2008 | 07:06 AM
mjsparky363's Avatar
Default odd dash light problem
Good morning all. Recently I acquired an 02 S60 2.4 NA and last night I noticed the hi-beam indicator , along with the key-in chime not working after i drove about 1/2 hour. This morning both the key chime and hi-beam light were working until I drove about 20 mins. It some how seems to be related to the temp. gauge. When the gauge is cold the lights and buzzer(also seat belt chime) all work, but when the needle gets about 1/3 they all stop working. I'm just wondering if anyone has ever had this or similar gremlins.? Thanks for any input.
Old Oct 18, 2008 | 08:52 AM
Default RE: odd dash light problem
Also check when this happens if the turn signals work and if the wipers only have one speed.
Old Oct 18, 2008 | 09:46 AM
yes, everything works , hi-beams, lo-beams , blinkers, wipers, just the blue hi-beam indicator key-in and seatbelt buzzer don't work. the red triangle that lights up with the key in and door open also works. probably won't ever figure it out and it doesn't seem to be causing any other problems. i don't know but maybe a ground is being lost? i don't have a wiring dia. so i don't know what else might be on that part of the harness. thanks for your reply.
Old Oct 18, 2008 | 09:53 AM
It might also be a software problem.
I would say to maybe wait and see if it causes anymore problems.
Old Oct 19, 2008 | 03:59 AM
swedes60's Avatar
about the seatbelt chime... should it be on ALL the time when the driver is not wearing a belt? Because mine goes off after about 5-10 seconds.
Old Oct 19, 2008 | 10:07 AM
I found a wire dia. online and it seems all the items involved go to the DIM ( dash instrument module) and there is also a CAN loop. I did try and "thump" the top of the dash last night and hibeam indicator came on? but only for a short time. Oh well I'll keep looking at the wire dia. and ..... thanks
Old Oct 20, 2008 | 03:25 AM
Before I destroy the dash, does anyone know how the thing comes apart on an S60 to get behind the instruments? Thanks.
Old Oct 20, 2008 | 08:33 AM
If I remember correctly the black besel just pulls out. Then there is 4 screws holding the cluster into the dash. Then it will slide out.
Onegin
Apr 4, 2011 07:13 PM
trumpy
Sep 9, 2008 08:18 AM
Macondawg
Aug 26, 2007 08:01 PM
unit03
May 7, 2007 09:12 PM
lotusing
Oct 11, 2006 12:42 AM
