p0016 p0017
Old Mar 25, 2024 | 04:22 PM
Sweetmelissa226's Avatar
Default p0016 p0017
i have a 2016 volvo v60 cross country that is reading the p0016 and p0017 codes? how serious is this? i’m guessing just a timing belt replacement
Old Mar 26, 2024 | 12:48 PM
well the codes are telling you the cam position sensor is reporting that the intake cam P0016 and the exhaust cam P0017 positions are out of spec. Could be one of several things - VVT solenoids/gears, wiring, cams jumped timing etc. Which engine do you have? (not all have timing belts - some have a timing chain). If you have a timing belt, how many miles on the car? I'd suggest you get a Volvo shop to do a scan to determine how far out of spec the cam timing is then check for other causes like fuses, wiring, grounds for the cam position solenoids, inspect the timing belt, check oil pressure etc. How is the car driving?
Old Mar 26, 2024 | 01:17 PM
it’s a timing belt. 2.5 engine. it’s been running rough and knocking from a bit. it’s runs but it’s stalls after 10 seconds of running. it look like the timing belt is loose abs may havd jumped timing
Cmurf
Sep 26, 2023 12:25 PM
kdanzige
Jun 25, 2022 02:40 PM
urdrwho
Jan 31, 2020 03:35 PM
Michelformika
Oct 12, 2017 04:31 PM
ronsivillo
May 10, 2017 06:18 PM
