P0026&0027 codes return - 2006 S60
About 2 month ago, my son's S60 2.5T got both VVT solenoids were replaced and engine hot-flushed. The diagnosis was both oil filters on the solenoids were completely plugged and one damaged due to sludge build up. Well, 2 month later the codes returned. I wonder if anybody had that happened and what was the final diagnosis?
Also, is it possible that the PCV box is bad and needs to be replaced (i.e., would it give these 2 codes)?
What brand was used on the replacement valves? They respond through oil pressure so any issue there can cause the solenoids to not operate as expected. Did you also replace the gaskets? They need to replaced as well.
You can test your PCV by using the "glove test" or putting your hand over the oil fill while the car is idling and see if you feel a slight vacuum. Lots of videos online for the glove test. Hand test is just as efficient.
OE would be ideal for this part. When mine went, I spent a lot of time looking online and saw bad reports from people who used aftermarket parts. The aftermarket is a lot cheaper, but you might not get the longevity. Are you using 3-4 quarts of oil per oil change? Around 1 quart is okay on a car of this age, but 3-4 is a lot. So it would need to be determined if it is being burnt during combustion, or if it is leaking. I don't know if using a thicker oil would affect the solenoids that much with the small difference between 5w and 0w. Isn't 5w-30 the recommended oil weight anyways?
