Pass. side CV Joint
Old May 12, 2018 | 12:14 PM
RPMCanes's Avatar
Default Pass. side CV Joint
What is a reputable aftermarket manufacturer? I looked on Moog's website and could not find a CV joint for my 2006 S60 2.5T. Any other suggestions? Thanks.
Old May 14, 2018 | 07:14 AM
pierremcalpine's Avatar
I've had really good luck just going to a reputable wreckyard and grabbing a used OEM one off them. If not, then I would go to FCPEuro.com and grab one from them.
Old Feb 7, 2021 | 11:06 AM
RPMCanes's Avatar
OK, so the passenger side inner CV Joint boot is cracked. Can I replace just the boot or should I replace the whole CV Joint? 162,000 miles.
Old Feb 12, 2021 | 08:28 AM
Dingus's Avatar
Inners seem to be the first to go due to being closer to the engine and heat. You can absolutely just replace the boot if you caught the issue quick. If you are experiencing any issues with the rzeppa joint then youd need a new CV. Boot isnt bad to do, just make sure to get a new axle bolt when you do the job as these are torque to spec. I also got a new dust cover while I was in there since they were cheap. You do have to separate the CV to replace the boot though. I just recently did mine, but I noticed it was split within a week of it happening.
elsortz
Apr 12, 2011 12:05 PM
mudpie
Feb 1, 2011 12:51 AM
Fade9150
Jan 16, 2011 02:14 PM
sjonnie
Sep 19, 2010 04:40 AM
RPMCanes
Jan 10, 2008 07:00 PM
