CV Joint replacement
Old Jan 9, 2008 | 07:49 AM
RPMCanes's Avatar
Default CV Joint replacement
I've got a 1998 S70 GLT with a torn boot on the driver's side CV joint. Should I replace the whole joint or just the boot? Also, if the joint is replaced, do any fluids have to be topped off like tranny fluid?
Old Jan 10, 2008 | 07:00 PM
Eric J's Avatar
Default RE: CV Joint replacement
If the joint looks clean inside, you may just have to replace the boot. If in dought, seeing that you have to take it all apart anyways, you might as well replace the axle also. It's about $100. Fluids remain the same.
dpvovo
Feb 18, 2019 07:41 PM
profcharlie
Apr 29, 2010 06:22 PM
axelm
Nov 6, 2008 08:33 AM
greeneyedgiant
Feb 6, 2007 03:45 PM
JPN
Sep 21, 2006 08:22 PM
