passenger side headlight doen't work
When you replaced the bulbs how did the wiring and plug look? Did you see any corrosion or heat damage? I would start by looking it over closely.
I had a turn signal socket go bad. The bulb still worked, but when I went to signal it went bonkers. No obvious damage to the socket. I replaced it and everything has been fine.
I hope that helps.
I hope that helps.
Markvolvo
12-29-2013 01:23 PM
ToledoVolvo01
04-30-2010 09:34 PM
paulfurtado91
01-24-2010 11:35 AM
