Performance upgrades 2013 2.5L Volvo S60 t5 pls help
I am looking for performance upgrades for my 2013 Volvo S60 t5 AWD, trying to increase power and make it look a little meaner, I have gotten a performance air filter from k&n and a high flow performance intake from snabb
I’m am very beginner and like DIY projects and would like to spend a total of $1,000-$2,000 on multiple upgrades starting with lower cost and ending with higher cost. Looking for upgrades that could cost $200-$600 each part. when I have time to save up the money I will upgrade the exhaust.
need for speed!
need for speed!
Wichy (03-14-2022)
my two cents is aftermarket cold air intakes are not very effective way of adding HP. Best bolt-on options are (in order of value IMHO): 1) ECU tune 2) bigger downpipe 3) larger turbo impeller/compressor 4) bigger intercooler. 5) free flow exhaust. Check out tuner packages (ie stage 1, 2 etc) to see what they recommend in terms of a blue print for parts. When you get into stage 2, that's where the special parts add up - things like boost controllers, bigger injectors etc may be recommended. With all that go-fast, don't forget you need to stop (and possibly turn). Vented/slotted rotors, bigger wheels/tires, fatter sway bars, strut tower bracket, performance strut/shocks etc. You may also want to dish out for a bigger oil cooler and transmission cooler if you are targetting 300+ HP at the wheels.
Wichy (03-14-2022)
could anyone possibly point me towards links to turbo upgrades as well as an exhaust upgrade for my 2013 Volvo S60 T5 AWD?
think that will do you,i know its for a ford but its the same turbo and manifold
