Power Steering
Old Jun 25, 2019 | 11:33 AM
Ryan Whalen's Avatar
Default Power Steering
Hello Folks. I have an 02 S60. Steering feels like there is no power steering. No leaks. Hard to turn and when turning, i hit spots where it is harder and the wheel doesn't come back to center from either direction. I turned on car and took cap off of reservoir and saw flow from return line. Power steering fluid is super dark. We sprayed u-joint 3 months ago when this problem started and it did help, but problem is back. Should I try a flush before I go straight into replacing the rack?
Old Jun 25, 2019 | 01:52 PM
start with the easy flush - buy a quart of ATF (such as dexron III), buy a turkey baster. If you have a short section of 1/4 ID hose you can fix 3-4 inches on the end to go deeper in the reservoir. Use the turkey baster to suck out all the fluid in the reservoir, then refill with fresh fluid. Start the car, turn lock to lock 3-4 times then shut off. repeat 3-4 times and each time the color should go from black to red. That will get you to be like 80% fresh for 15 minutes of time and $6
burberry
Apr 23, 2015 07:49 AM
Biomass
Jun 6, 2011 01:32 PM
earthbound741
Feb 28, 2011 12:12 AM
tmixdorf
Aug 31, 2009 08:25 PM
Alex11
Apr 12, 2009 09:35 PM
