Programming a S60 Remote
Old Dec 14, 2005 | 11:22 PM
gwp02035's Avatar
Default Programming a S60 Remote
I just purchased a 2001 S60 T5 that did not come with any keyless entry remotes. I purchased two on line for cheap, but do not know how to perform programming. Can anyone offer assistance?
Thanks[:-]
Old Dec 15, 2005 | 01:06 PM
reg's Avatar
reg
Default RE: Programming a S60 Remote
Well, if it is similar to what is used on a C70, you had best up your Visa limit as only the dealer can program the remotes. Not only will the dealer charge for his service, but Volvo gets a dollar or two also for the program.
Reg
Old Dec 15, 2005 | 10:49 PM
S60 R's Avatar
Something like $200-$300 the dealer charges, from what ive seen.
Old Dec 16, 2005 | 02:50 PM
reg's Avatar
reg
Well, you peaked my curiosity and so I looked up what the dealer charged me last year. I was wrong..............it only cost $79.49. I believe I was also thinking of what I paid for the actual remote. At any rate, if 02035 already has a remote I guess the cost is not as bad as we thought.
Reg.
ORIGINAL: S60 R
Old Dec 16, 2005 | 08:39 PM
But If he Doesn't have the proper CODES they will only be good for the Garbage.
Old Dec 17, 2005 | 02:42 PM
reg's Avatar
reg
TECH, what do you mean by codes? On the late model c70's the dealer sells you a remote (the same as buying off Ebay) and then the dealer programs the remote to your auto. I had an aquaintenance who purchased his remote from Ebay and took it to the dealer who programed it...................is a S60 different? Also, Merry Christmas to you!
Reg.
ORIGINAL: tech
Old Dec 17, 2005 | 04:36 PM
Yes the S60 is different. They need codes to be programmed.
Old Dec 17, 2005 | 05:09 PM
reg's Avatar
reg
Jeez..............don't you wish Volvo could get it together and make universal parts??!!
Reg.
ORIGINAL: tech
Old Dec 17, 2005 | 07:12 PM
YES
Old Oct 25, 2017 | 08:50 AM
edmonton.guy's Avatar
Default Remote info
Hey Guys,
I recently picked up a 2002 Volvo S60 2.4 Turbo AWD and it came with only 1 manual key.
So I was looking for keys/remotes for it and after a little bit of research I have realized that it has to be programmed by Stealership ONLY.
I found some remotes on eBay but I am not sure if they are compatible as I dont have original remotes.
Could anyone of you tell me what is the FCC Code/GM number on the back of the remote for a 2002 Volvo S60 2.4 Turbo AWD?
That would be helpful for me to source a cheap remote and then get it programmed at the stealership. Thanks in advance!
Old Oct 25, 2017 | 11:51 AM
ES6T's Avatar
Originally Posted by edmonton.guy
Hey Guys,
Unless you have the original codes, a used one will not work.
And it's dealership.
Old Oct 25, 2017 | 12:57 PM
I am not buying a used remote but its an after market one.
I need to confirm the FCC Code/GM Number on the original remote and match it with the number on the after market remote.
Remote I am planning on buying is:
2 New Replacement Keyless Entry Remote Car Key Fob Control for Volvo HYQ1512J 4B | eBay
Old Oct 25, 2017 | 01:09 PM
ES6T's Avatar
Those are not for your car.
Old Oct 25, 2017 | 03:52 PM
Thanks for your information.
Padrea
Aug 31, 2022 03:01 PM
Psaboic
Jan 3, 2009 04:46 PM
davidch2
Apr 9, 2008 07:44 AM
Sasha
Aug 5, 2007 08:29 AM
sudvam
Oct 30, 2003 12:56 AM
