Purchased 2003 S60 AC not working.
Old Jun 13, 2013 | 11:20 AM
Zeecar's Avatar
Default Purchased 2003 S60 AC not working.
Hello everyone! Hope to get a bit of advise, great forum, done quite a bit of reading already. Priceless really!
I just purchased the car, Naturally aspirated btw. The previous owner said he took it into find out the A/C issue and was told it required a new ECU. Could this be correct? If so i had no idea the AC was controlled by it.
Thanks for any advice you can provide.
Old Jun 22, 2013 | 11:56 AM
go-part's Avatar
Former Sponsor
Troubleshoot Automotive Air Conditioning Problems
Old Jun 22, 2013 | 03:05 PM
MYS6T's Avatar
that sounds a little crazy But i guess possible. What usually happens with these cars is the clutch or bearing goes in the AC unit and this empty the system or if you are like me the clutch seizes up and blows the sep belt in to bits and destroys the power steering pump pulley with it.
Now the AC units are expensive to buy new /rebuild but the salvage yards are full of them and at $75 its worth the try.They pretty simple to replace your self or a 3hr job at most shops.
Is the AC making any noise when it is on and clutch in engaged ? when you turn it on does the clutch engage ? You should be able to hear it when it kicks in. The car will idle a little different..
richardgrant
Apr 28, 2015 08:22 PM
rspi
May 15, 2014 07:36 AM
robytes
Jan 31, 2009 08:41 AM
BigAdam
Oct 21, 2008 10:01 AM
