Question about freeze plugs/sales guys
I am considering buying a 2002 S60 2.4 manual transmission (yes I really want that). I took it from the dealer to a volvo mechanic and the mechanic noticed it leaking oil pretty bad. Also, he reported (which I then noticed) that the engine speed would vary while idling and would 'lurch' at low speeds. His report was that the oil cooler is leaking and then throttle house needed to be cleaned. Not that big of a deal. I didn't use him before, so I don't completely trust him, but at least he isn't the dealer.
The dealer says that the description is wrong, and the problem is a cracked freeze plug.
Anyone know if the freeze plug could cause the rev issue? I suspect it could explain
the leaking fluid.
It is hard to find manual transmission S60, and the mechanic said the car looked pretty
good besides these two issues.
Should I believe the dealer and let them fix it? Should I just run away and keep looking?
Thanks,
Craig
the leaking fluid.
Thanks,
Craig
Kyle Pancis
11-02-2014 07:14 AM
AnEskimo
10-09-2010 12:13 PM
