Question about my 01' s60 (Answer what you can)
Old Nov 15, 2007 | 07:31 PM
Scott6's Avatar
Default Question about my 01' s60 (Answer what you can)
OK, few questions.. I have had this card for about 1 year now, its a 01 S60 5T 82k miles
1. Stearing: The tires rub, as fas as I can tell its not lowered at all, it seem just as high as any other s60. But as full turn the tired rub! The struts look to be stock (prolly orignal) but I didnt think this would cause a problem, I dont remember it rubbing when I bought it. But now at full turn, like U turns it rubs pretty bad.
2. Stearing: The searing radious seem redicouscly wide? The car needs more room to turn that my 3/4ton.
3. Noise: I get a clicking noise comming form under the dash (herd form inside cab) when I push the break. Like if I just barely push it in and out the clicking is fast. Like part of the mecinism. Is this normal?
4. Dipped beam failure. The lights stay on, but the error flash on and off alot while driveing. (tonight im gonna try to find the relays, I guess one could be bad, or loose or dirty. Any other thoughts?
5. Ticking/clicking from the engin. It sounds like the valuvs, but with dual overhead cams, I cant see this being a problem. It has been clicking since i bought, but latly it seems louder. Do I need a timming adjustment? Im going to try to get a sound recourding of this and post it up.
6. Gas milage, 16-17mpg city.. and im being nice on the foot. when I bought it it was around 19-21. Recently, I had 3 out of 5 coils die. So I replaced all 5 of them. I now have 5 new coils installed (and 2 extra for backup ) I also put in some botch plugs (mid-high end set) as well and a new air filter, it seems that the milage as went south after all this. Something wrong? Can over torqueing the plugs case milage problems. I run 91 octain from chevron or citco, and for the last 2 tanks have used shots of Lucas injector cleaner with the fill up.
7. Clicking on front end. It feels like a bearig poping, when I slow down and turn like out of a driveway it clicks pretty loudly sometimes. ??? tie-rods? bad struts? drive shafts?
8. The shock in the glove compartment broke, when can I get a peplacement other than a dealer?
-sorry this is long thanks for reading if you did.
-Scott
Old Nov 15, 2007 | 08:39 PM
hodelam's Avatar
Default RE: Question about my 01' s60 (Answer what you can)
The answer to #3 is the brake light switch and this is a normal sound.
Old Nov 15, 2007 | 09:23 PM
1. Do you have 17 inch tires? If so that is normal.
2.Normal
3.When you hear it do you feel a clicking by the shifter?
4.Headlight bulb bad or going bad.
5.Oil pan o-rings might be bad causing lower oil pressure and noise.
6.Not to sure maybe dirty throttle body.
7.Are you at full turn? Do you also hear it going over bumps?
8.I don't think anyone besides the Dealer sells them. Have you checked out the post in the general section with all the parts sites?
Old Nov 15, 2007 | 10:48 PM
Scott6's Avatar
ORIGINAL: tech
2.Normal
1. yes i do
2. sucks... ohh well ill deal
3. Yea I figured out tonight that its the shifter releaseing so I can go into gear.
4. hmm intersting... I have installed new bulbs like 3 times...
5. That sounds fun.. arg... I didnt know low oil presure would cause noise.. My oil is not burning, in fact its never low all thru the oil change to oil change, the onoly time i put oil in is at a change.
7. no not at full turn.. sometime wil will doit when im backing out of a car port.
8.figured.
Old Nov 16, 2007 | 08:17 PM
4.If the bulbs work fine and you have the message or if both lights go out the shunt under the dash in the main computer might have a bad connection.
7. Maybe a bad axle is the boots ripped?
Old Nov 20, 2007 | 10:45 AM
Scott6's Avatar
Ill check that stuff out, thanks.
volvo00
May 21, 2011 01:41 AM
Typhoon
Jul 11, 2010 10:18 AM
DRKSIDExrs
Aug 28, 2009 07:59 PM
Coastal
Oct 4, 2007 05:22 PM
