Radio problems
Old Oct 11, 2020 | 12:05 AM
Johnseed3's Avatar
Default Radio problems
I have 2006 Volvo S60 2.5t. The radio does not work consistently. It will sometimes sounds just fine and other times it just seems likes it’s off (changing volume doesn’t do anything). When not working, pressing the next station button, it just continually goes through the stations and never settles on one (on am or pm). Also, sometimes itll be able to settle on a station but make no noise but be able to show the song/station name on the display. What could be the problem? Don’t know which exact radio unit it has but it has the 4 ***** to adjust the radio and no cassette.
Old Oct 12, 2020 | 03:36 PM
does the CD player work ok? I'm assuming so as your symptom sounds like you have an antenna/antenna amp issue where it cuts out from time to time.
Old Oct 12, 2020 | 04:31 PM
Johnseed3's Avatar
CD works fine. Previous owner said it was the amp or something like the at
Old Oct 13, 2020 | 03:18 PM
could be something like this:
https://www.ebay.com/itm/2005-2009-V...-/302801018317
Old Oct 13, 2020 | 11:58 PM
Johnseed3's Avatar
Where is that located?
Old Oct 21, 2020 | 08:30 AM
bob-XC60-13's Avatar
Just bought a used 2013 XC60 with intermittent radio problems, radio turns on sometimes sound, sometimes not....
When turning radio on, if speakers pop as turning on, then NO sound...if I do not hear the speaker pop the sound works.
I first solved the problem by accident, radio went off driving car home from dealership(1st prob at dealer)....stopped car restarted turned radio off and on, heard nothing, gave up, turned on NAV and all of a sudden sound, switch to radio no sound, switch to cd sound, switch back to radio sound, lasted rest of 1 hr trip home...worked for 2 more days starting multiple time....
took to local Volvo dealer said they pulled multi codes and multiple DTC'S for AUD-IF will need to remove pass seat and check wiring at radio amp....rep also said problem might be solved by turning off SAT RADIO???
any idea of a solution??
Thanks my first post, but hopefully not my last...I will be searching more threads for possible answer.
Old Feb 3, 2022 | 03:57 AM
JoannaB's Avatar
The radio in my 2014 VolvoS60 stopped working. I can only hear the Sirius radio add. None of the top buttons work, radio. Media my car etc.
Old Feb 3, 2022 | 03:59 AM
JoannaB's Avatar
Volvmar
Nov 10, 2023 12:24 PM
03v70
May 28, 2011 08:34 AM
jring
Apr 23, 2009 03:01 PM
mickey
Jun 16, 2007 09:50 PM
sbeemish
Sep 15, 2004 02:48 AM
