Rear strut removal of 2006 S60
How difficult is it? Is there a site I can go to? In terms of mileage, when do you change the front shock absorber and rear strut last. Mine has 118K miles. I feel that both need replacement already. My wife also drive 2006 S60 with 58K miles and suspension is still tight. I can feel the difference.
Thanks
Miles
Thanks
Miles
Not positive if 06 and 08 have same suspension configuration but I would like to believe it is the same. Yes, remove 1st the top bolt 19mm using torx (#5 or #6)
& then bottom 15mm and slide out the shock. Need to jack up the car a bit higher so
you can easily slide the shock. Wondering how many miles your wife's 08 has?
Mine has 118K. Mine are both bad left and right. One has lost the pressure
while the other has zero pressure at all. My sway bar link still in very good shape.
Next job will be front shock when weather warm a little bit.
Wife's 08 has 83k on it. We are getting ready to do timing belt, water pump, serpentine belt, plugs, etc. I drain and refill the transmission fluid with 3309 every other oil change so it stays fresh. I've heard the shocks will need replacing around 100k and I can tell the car has more body roll and doesn't absorb impacts like it used to. Car runs great and has no problems.
