Reduced engine performance
Old Feb 22, 2022 | 08:00 PM
Prettycar's Avatar
Default Reduced engine performance
Hi. On the freeway my car wouldn't accelerate and dropped down to a slow crawl and it says reduced engine performance. I crawled all the way on the shoulder til the next exit then stopped and turned my car off. I waited a minute then restarted it and although the message is still on and the check engine light on too, I was able to drive normal the rest of the way back home. What do I need to do? Is this because I'm almost due for an oil change? Or the fuel sensor? Can I just wiggle something? How much will a repair cost?
Old Feb 23, 2022 | 05:59 AM
Dingus1's Avatar
You would need the car to be scanned to see why it went into limp mode. Restarting the car will take it out of limp mode, that's why it worked fine after.
Old Mar 3, 2022 | 04:47 PM
CNDVolvoGal's Avatar
My '12 xc70 just gave me this same msg for the first time tonight. I'm trying to figure it out! Not a super obvious resolution. Grrr!!
Old Mar 3, 2022 | 08:19 PM
The reduced engine performance is the computer's way of keeping you from doing serious damage to the engine when a problem has been detected. There will be stored fault codes that triggered the warning which should be read by a diagnostic tool. If you want to read the codes on your own, you can buy a $30 OBD2 scanner at Harbor Freight or "rent" (usually for free) a scanner at Autozone etc. If your not that handy, book some diagnostics time with your dealer or Volvo friendly shop asap. It could be something simple like a mis-fire caused by a bad coil or an intake air leak, or it could be something more involved that if left unattended could cause valve or piston damage. Spending the $100 for the diagnostics is way cheaper than $3000 for a rebuild...
Old Mar 3, 2022 | 08:47 PM
Originally Posted by Prettycar
my car wouldn't accelerate and dropped down to a slow crawl and it says reduced engine performance. I was able to drive normal the rest of the way back home.
What year is your car?
It's has nothing to do with an oil change.
You can't just wiggle something (well you can, but it won't help)
No way to tell how much this will cost without a diagnosis. For instance if your car is a 2001 you might have a bad throttle module. But we don't have that info yet. As others have mentioned a scan with a compatible scan tool would be your first step.
Old Jan 31, 2025 | 05:18 PM
Kadora's Avatar
I have a 2019 XC 90. I got the message of reduced engine performance with the little turtle pic back in 2021. I took it to the dealer and they fixed it as part of recall R10100. Fast forward to January 2025, my car stops with the same message. A mechanic came to my house and told me exactly what it was, and recommended that I go back to the dealership because the recall had already been done, but it still blew the same fuse. The recall was pertaining to the same fuse but it was blowing on key off due to voltage spikes. If the fuse blows with the key on, it has to be the pump or wiring.
Long story short, the dealership is telling me that they need to replace the fuel pump module again, and the cost is $820. Is that acceptable? If it was a recall, do I need to pay again? What the advisor said is that for a recall, they only fix it once and no more… why is it happening again? I don’t wanna pay $820 for some faulty Volvo part. Is it going to happen again in three years?
Gratefuldad
Nov 13, 2020 12:15 PM
Tanz
Nov 6, 2019 10:06 AM
Waltonsivania@gmail.com
Sep 25, 2016 11:30 PM
hojov
Jun 30, 2012 11:54 AM
mces80
Jun 19, 2009 10:14 AM
