Replace rear sway bar end links
Hi,
I bought a pair of rear sway bar end links from ipd to replace the worn out factory ones. I could access the link without jacking up the car by crawling from the rear. However I couldn't get the bolt to turn at all on the original link even after I spray on some WD-40. Should I continue with brute force or use a longer ratchet or there is some tricks to get this thing off??
thanks
Mingster
thanks
Mingster
