Replacing the crankshaft
Hello,
In continuation from a prior thread...
https://volvoforums.com/forum/volvo-...signal-107200/
I'm in the process of rebuilding the engine, and need advice on which parts I need to purchase:
What are your thoughts? Am I overthinking this job? Should I do any additional work while I have the opportunity?
- The cylinder head was serviced at a machine shop and is ready to re-install.
- The crankshaft needs to be replaced. I picked one up at the salvage yard (same year/engine code).
- The crankshaft has been cleaned and polished - I was advised that that everything looked good and that it won't need oversized bearings
- With the new (used) crankshaft, will I need to replace the main and rod bearings?
- Piston rings.
- Rod bearings
- Main bearings
- Front and rear mail seals.
- Oil sump gaskets.
- Oil cooler gasket.
- Oil pump gaskets.
- Flywheel & clutch, clutch slave cylinder.
Yes, I would have replaced the stripped gear, fixed the head, put a new timing belt on (or reused the old one if relatively new) and driven away happy. The gear is not going to come loose/strip again once you have a nut holding it down. Yes there was wear visible on your old crank, but with some lock tight and a new nut would have been fine.
You are spending close to the value of the car on repairs - it does not make economic sense. (yes I know you got this and that used and your time is free, but it is still a 19 year old s60 non turbo)
