Replacing door pulls
Old Jul 9, 2011 | 09:57 AM
tylerdurden4543's Avatar
Default Replacing door pulls
Hi all,
I'm trying to replace the doorpulls on my 2007 S60. Per the instructions from the members build thread, I've removed the cover and the two torx screws but the pulls will not release from the door -- are there screws on the opposite (interior of the door) siding that are holding it in place? Do I need to remove the entire panel to access them?
Thanks,
Tyler
Quote:
Originally Posted by 01_fast_ride
Using the bone tool, remove the front cover on the door pull. From below, you will see a small recess in the door pull as a perfect starting point. With a twisting motion, go along the edge of the cover until it releases.
Using the Torx bit and ratchet, remove the 2 screws on the door pull.
Old Jul 9, 2011 | 09:20 PM
01_fast_ride's Avatar
I don't remember the door pull being removable from the panel. If you've made it that far, I would just go the extra distance and remove the whole panel.
(I love that the member write-up is getting a lot of use. Makes me feel good that I could contribute some how.)
bestharry
Feb 20, 2009 09:38 PM
tjmm1335
Feb 11, 2009 02:03 PM
alexr2130
Aug 11, 2006 11:25 PM
jerryman
May 23, 2006 01:19 AM
claunch
Mar 27, 2006 06:12 PM
