Rodents!
Old Apr 28, 2013 | 04:18 PM
Code4code5's Avatar
Default Rodents!
I'm new here, but have searched repeatedly and haven't found anything that might help. I haven't driven my 2001 S60 for a while and discovered that a rabbit has made the engine compartment it's home. The only real damage I see is that the rabbit has eaten all of the wires that run from the fuel injectors. There's enough wire on the harness end that I should be able to splice new wires to replace the missing ones.
My question is whether anyone knows where I could fined a complete replacement harness for the fuel injectors. Secondly, what would be the best connector to use to facilitate the splice? Any ideas?
Thanks in advance.
Old Apr 29, 2013 | 06:58 AM
ES6T's Avatar
The harness for the injectors isn't separate, it comes with the whole engine bay harness. So you'll have to fine one in a junkyard and cut that section off.
For the splice, use heat shrink butt connectors.
