Rusted brake caliper piston - is this normal?
Old Mar 22, 2010 | 06:56 AM
spiderdan's Avatar
Default Rusted brake caliper piston - is this normal?
I replaced the front brake pads on my '07 S60 (16K miles) yesterday and when I removed the inner brake pad from the piston, the inside of the piston cylinder was extremely corroded (see pic). This was apparent on both sides. Is this normal?
When I removed the pads, it appeared there was still a good amount of pad left exept the top/bottom of the pad (where it concaves in) was deteriorating away. When I would applied the brakes, it felt like there were no pads left which caused me to assume they needed replacing. Now that they're replaced, there's a noticable difference but I'm still feeling a slight vibration when making sudden stops.
Old Mar 22, 2010 | 10:50 PM
TurkeyVegas's Avatar
Default Water = Rust
I clean mine up then I take a hypedermic neadle with rabestas oil (spell?) inject in top of boot good to go if the boot is torn rebuild calipers or go new can't stop rust..
Old Mar 23, 2010 | 03:12 PM
lancaster1's Avatar
My 05 v70 and 06 s60 look exactly the same as yours. I asked the dealer what they thought of it the first time I changed the brakes (stillman volvo, west chester, PA). They said it was harmless and normal - glad I have the 100K warranty. At this rate the caliper pistons will be dust in a few years.
Old Aug 7, 2010 | 01:24 PM
matamoris's Avatar
Does is snow a lot in PA? Lots of salt on the roads during the winter? I understand this greatly contributes to rust on these components.
Matt
Old Aug 8, 2010 | 01:02 PM
Manu Noypi's Avatar
Never saw rust on my calipers. Yours need a lot of cleaning. For those living in snowy
areas and salt is used on the roads, it would probably be best to flush brake fluids
after winter to remove moisture in the system.
malcolm2
Jun 25, 2015 08:16 AM
rmosser
Jul 14, 2013 11:47 AM
vpatrol
Apr 20, 2012 08:22 PM
volvo_s70
Jul 9, 2008 10:54 PM
chrismears
Dec 11, 2005 11:35 AM
